08-18-2015
04:47 PM
02:58 PM
I cannot scan since downloading Windows 10. It says: You don't have the required privileges to access the specified folder Code 9,244,3
09-28-2018 03:41 AM
11-08-2018 01:10 PM
Worked for me too. Many thanks. I spent far too much time on this before I came across your post.
12-29-2018 09:16 AM
01-09-2019 12:07 AM
I disabled Windows Defender so that worked on the "Do not have privelege to access specified folder". I can scan now and click "Share". Then attatch document to email, send it, only to find out that it can't be opened by person receiving it. I double checked by going to "Documents" where it is stored. It will not open there either. Any tips will be greatly appreciated.. I wonder if they sell Carrier Pigeons ??
02-28-2019 12:13 PM
03-05-2019 03:35 AM
yes, and it has worked for me too ![]()
04-01-2019 11:51 AM
09-03-2019 04:50 PM - edited 09-03-2019 04:53 PM
In Windows 10 in 2019, I found out that approving the App in "Windows Security" solves the issue. It seems the issue is a consequence of enhanced security in W10 due to malware and software trying to highjack files. I saw in the thread that some people suggested to completely turn off the "Controlled Folder Access" (in Defender). I suggest instead you allow the app. Doing this sorted out my problem.
Go to "Windows Security".
Then go to "Virus and Threat protection".
Here you find a "Controlled Folder Access".
Here choose to allow the app - Click the plus + sign, Add app, then choose in the listing of the last denied app, the app you would like to allow.
10-10-2019 12:57 AM
Thank you for the tip. I just disabled Windows Defender and once finished scanning I enabled Windows Defender.
Worked a treat.
03-05-2020 01:59 PM
What a relief !! Finally have my Canon MG3520 working properly again. Is Canon the only one having problems from Windows Defender ?. Thanks for the help !!.
