08-18-2015
04:47 PM
02:58 PM
I cannot scan since downloading Windows 10. It says: You don't have the required privileges to access the specified folder Code 9,244,3
03-17-2017 08:29 AM
When choosing a folder for saving scanned document, I receive the following message:
"The Login account does not have the required privilege to access the specific folder"
How can I solve this problem?
10-01-2017 01:49 PM
05-21-2018 03:25 PM
I have found the solution with new windows 10...
1. Open Settings
2. Selet "allow app to go through firewall"
3. select "change settings"
4. Select and allow "File and Printer sharing"
Action 2
1. Open settings
2. Open Virius and threat protection
3. Open Virius and threat protection settings
4. Open manage controlled folder access
5. Open allow an app through controlled folder access
6. Add this file to list to allow: C\Program Files (x86)\Canon\IJ Scan Utility\SCANUTILITY.exe
I did both and on all computers and I'm good to go! Good Luck!
05-21-2018 03:29 PM
1. Open Settings
2. Open "Firewall and network setting"
3. Selet "allow app to go through firewall"
4. select "change settings"
5. Select and allow "File and Printer sharing"
I forgot step two in previous post...
07-07-2018 04:10 PM
baily71's solution worked the best (for me, anyway).
Thanks baily71.
07-11-2018 01:42 PM
07-13-2018 09:55 AM
Hi JLRC2
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
08-17-2018 10:53 PM
Many thanks bailey71. Your solution worked perfectly. I was starting to get very frustrated.
08-18-2018 11:45 AM
Resolved by uninstalling and reinstalling software. Thanks.
09-18-2018 04:47 PM
This is a Windows 10 problem. This Canon Error Code 9,244,3 (when trying to scan a document) stared after I installed Win 10 Feature Update 1803. I tried everything suggested in this thread, plus a few other things, to no avail.
I stumbled across the solution by clicking on the Windows message itself in the Notifications bar on the right side of the screen. Doing that presented me with a settings screen entitled (in tiny letters) Windows Defender Security Center. Under that it said Allow an App through Controlled Folder Access. Click the + sign to Add an Allowed App and up pops a mini file explorer. Browse to your Program Files folder(s) and select the executable (.exe) – in this case SCANUTILITY.exe. My Canon scanner (MX922) works fine now.
As an alternative, open Windows settings, search for Controlled Folder Access to access the Add App panel to turn off the Controlled Folder feature entirely.
M$ is extending its control in protecting folders to what it thinks is best for us. I’m done with their **bleep** Feature Updates screwing everything up.
