05-04-2014 12:19 PM
I am attempting to print the Network Information on an MX410 all-in-one.
I press Menu until I come to Device Settings / Print Settings. At that point, if I press OK I am taken to Prevent Abrasion,while if I press > I am taken to Device Settings / Lan Settings. Then, if I press >, Device User Settings and then PictBridge Settings. If, on the other hand, I press OK at Device User Settings, I am brought to Device User Settings / Date/Time Settings.
Any help would be appreciated.
Thanks,
s660117
06-04-2014 08:33 AM
Hi s660117,
Please follow these steps to print the network settings of the printer:
Make sure that the machine is turned on.
Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
Press the Menu button repeatedly and select Device settings.
Use the ![]()
button to select LAN settings, then press the OK button.
Use the ![]()
button to select Print LAN details, then press the OK button.
