08-26-2020 12:02 PM
I've got an MG7520 that is currently tied (wirelessly) to an old Windows PC. I'd like to be able to scan to other devices(Macs). Is that doable? Thanks in advance.
09-04-2020 10:21 AM
Only one scan to destination is supported for each operation.
Example:
If you have 5 computers, you would need to perform 5 scan operations for each to receive the the output.
Scan to:
PC1
then
PC2
then
PC3...
This should help:
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MG7500%20series/EN/UG/ug_scanning0600.html
08-27-2020 08:37 AM
Hi, swami7774!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
08-27-2020 02:07 PM
I hope this site is of more help than contacting Canon directly.
09-03-2020 08:57 PM
I have a Pixma 7520. Can I configure it to scan to multiple devices or must it be tied to one computer at a time?
TIA.
09-04-2020 10:21 AM
Example:
Scan to:
PC1
then
PC2
then
PC3...
This should help:
09-04-2020 04:44 PM
Thanks. That gets me partially there. I may not have been clear enough; I'm not looking to scan to multiple devices simultaneously. I'm looking to configure the Pixma to have a choice of scanning destinations: PC, MacBook, iPad ,etc I think from quickly reading the link you sent, that I can do that. Am I correct?
09-05-2020 12:58 AM
You are correct.
