03-18-2015 05:41 AM
I recently moved and have lost the setup disc for my MG3122 printer. Can it be setup without it for wireless use without it or where can I get another copy of the setup disc? Any help would be greatly appreciated.Thank you
03-23-2015 03:01 AM
Hi glass9711,
The printer can be setup wirelessly using the latest drivers from the Canon USA website. So we can provide you with instruction for downloading the drivers applicable to your computer, please reply with what operating system you have (version of Windows or Mac OS X).
We look forward to hearing from you!
If this is a time-sensitive matter, additional support options are available at Contact Us.
03-23-2015 03:01 AM
Hi glass9711,
03-23-2015 06:45 AM
03-24-2015 08:49 AM - edited 03-24-2015 08:50 AM
Hi glass9711,
Before installing the drivers, please ensure that any antivirus for firewall software that is on your computer is temporarily disabled, as these programs can sometimes block the printer from being detected on the network. Once the printer is detected successfully, the protection software can be re-enabled.
Please click here to go to the Drivers and Software page for the PIXMA MG3122. Once on the initial download page for your model, please do the following:
1. Verify that the operating system detected in the "OPERATING SYSTEM" drop-down menu is correct, and if it is not, please click the drop-down menu to select your operating system.
2. Next, please click on the red arrow next to the "RECOMMENDED DOWNLOADS" section and click the MINI MASTER SETUP file. When you do, a red DOWNLOAD button will appear. Please click on the checkbox below the DOWNLOAD button, then click the red DOWNLOAD button to begin the download. The time for the download process may vary depending on the speed of your Internet connection and the size of the file being downloaded.
Once you have downloaded the Mini Master Setup file, please follow the steps above to also download the Software for the printer from the Software section. Once all items have been downloaded, please double-click on each item and follow the prompts to install the drivers and software on your computer. Please install the Mini Master Setup file first.
Hope this helps!
This didn't answer your question or issue? Please call or email us using one of the methods on the Contact Us page for further assistance.
10-15-2022 08:38 PM
I recently moved and have lost the setup disc for my MG3122 printer. Can it be setup without it for wireless use without it or where can I get another copy of the setup disc? Any help would be greatly appreciated.Thank you.
Operation system version Windows.
08-18-2023 02:30 PM
I have a MG3122 printer that I want to use with a new HP ENVY laptop, how can I get the necessary software and drivers to complete the setup?
