04-06-2013 08:29 PM
I am currently printing from my computer to a new MX892 via a USB cable. I was afraid to set up wireless in case that would mean I could only print wirelessly, which is likely not true. I might (rarely) choose to print from my iPad or iPod wirelessly, if that was an option. My question: Can I set up wireless printing for those rare occasions without creating problems for printing via USB the majority of the time?
04-08-2013 08:42 PM
Hi Jswayney,
As long as you are not setting up both Wireless and USB connections on the same computer, you should be fine. For example, you can have the printer working fine connected via USB, then set the printer up on your Laptop as strictly wireless and it won't have any effect on your desktop computer. The same goes for our iPad. Since the MX892 supports Airprint, if you have the printer configured wirelessly and use the iPad to print wirelessly, the desktop should remain uneffected.
04-15-2013 11:18 PM
This is similar to a question/problem I am having. I originally set up my MX892 for wireless connection. Rather than printing, I am actually scanning a fairly large volume of documents. For only occasional/light scanning the wireless works fine, but I would like to connect by USB for these larger jobs. Is there any way for me to use the MX892 with a USB connection now without reinstalling the software and changing the conneciton method (on the same computer)? I have tried hooking up the USB connection and it doesn't appear to work with the scanner; oddly, it works fine for printing.
04-20-2013 04:55 PM
01-27-2015 11:27 PM
thank you, thats great. so how do I get my lap top, IPAd, and others
to set up and recognize the wify printer?
thanks!
01-29-2015 01:15 AM
Please, what steps do I take to set up
the MX892 to configure wirelessly so then I use the iPad, phone, etc., to print wirelessly?
It is already cabled to my main computer and works well.
thank you
01-29-2015 08:57 AM
Hi paulb,
You will need to connect the printer to your network wirelessly prior to printing from your iPad and iPhone. To setup the printer wirelessly, please follow the steps located at the link below related to your operating system:
Once the printer is connected wirelessly, you can setup your iPad and iPhone to print via AirPrint. To do this, please follow the steps located here.
Hope this helps!
