10-30-2022 07:44 PM
I have, for years, used HP printers and I may have been spoiled by HP Scan, which is simple to use but quite effective for my purposes. Specifically, it has the following capabilities that I use quite frequently, but which do not seem to exist in IJ Scan:
All of these capabilities are there before you save the scan as a document. When you save the scan, you get a file dialog and name the file yourself, rather than having it saved as some formulaic name ("IMG" + suffix). Of course, HP Scan allows you to control resolution, scan size, output type, etc, as does IJ Scan, and it even has an OCR scan, though I have never used that capability.
A little web search shows there are numerous programs that allow you to control scanning, but most of them are either far more complicated (with more capabilities) or are substantially expensive - usually both.
Can anyone suggest an alternative scanner app/program for Windows 10 that would have all the capabilities in my bulleted list above, but without going overboard on added features? Doesn't have to be free, but I won't pay over $100 nor will I pay for a subscription.
Thanks.
10-31-2022 12:17 AM - edited 10-31-2022 12:18 AM
Google VueScan
hamrickdotcom
Google VueScan
hamrickdotcom
11-03-2022 08:12 PM
While I don't yet like it as well as the free and simpler-to-use HP Scan, VueScan seems to do the job and has a few extra features. Thanks for the recommendation.
