ATT changed my WiFi netork. How do I change it on my canon PIXMA TS3722
curlprince
2 ACCEPTED SOLUTIONS
DerrickL
First thing your wifi network must have an active 2.4ghz signal. If it is working you can log on to it using this method;
Steps to Manually Connect Canon PIXMA TS3722 to Wi-Fi
Prepare for Connection
  • Ensure the printer is powered on and connected to a power source.
  • Confirm that your Wi-Fi network is active and you have the SSID (network name) and password ready.
Access Printer Menu
  1. On the printer's control panel, press the Home button.
  2. Navigate to Settings using the arrow keys.
  3. Select Wireless LAN setup.
Select Connection Method
  • Choose Other Methods or Manual Setup from the options presented.
Enter Wi-Fi Details
  1. Select your Wi-Fi network (SSID) from the list.
  2. Enter the Wi-Fi password using the printer's keypad. Use the arrow keys to navigate through characters.
Confirm Connection
  • After entering the password, confirm the settings.
  • The printer will attempt to connect to the Wi-Fi network. Wait for a confirmation message.
Test the Connection
  • Print a network configuration page from the printer's menu to verify the connection status.
Stephen
Moderator
Moderator
Hello! We understand you need to reconnect your Canon PIXMA printer to a new Wi-Fi network after ATT changed your network.
You can reinstall the software to re-pair your printer. Get it from https://ij.start.canon/ts3722
If reinstalling the software doesn't automatically pair your printer, you'll have to manually re-pair it. Here's how:
  1. Enter Setup Mode: On the printer's control panel, press the Setup button.
  2. Wireless LAN Setup: Use the arrow keys to navigate to Wireless LAN setup, then press OK.
  3. Select Your Network: The printer will scan for available networks. Select your new network (the one provided by ATT) and press OK.
  4. Enter Password: Enter the password for your new Wi-Fi network. Use the arrow keys to input the characters, then press OK.
  5. Confirmation: The printer will attempt to connect to the network. Once connected, a confirmation message will appear.
    **for illustration purposes only** may contain mistakes**for illustration purposes only** may contain mistakes
If you encounter any issues, please refer to the printer's manual or visit https://canon.us/account for more detailed instructions and troubleshooting tips.
3 REPLIES 3
DerrickL
Access Printer Menu
Enter Wi-Fi Details
Confirm Connection
Test the Connection
Wanted to add the following to my colleagues reply.  Take a look at the side or the bottom of your AT&T router.  There should be a sticker black or yellow that has the device's access code as well as the pre-configured networks.  2.4 and 5G.  If the networks aren't there, you can use a web browser to log in and check it.  Copy the access code from the sticker. You'll need that to log in.
The IP address of the AT&T router will be 192.168.1.254
You'll need the access code to view its settings.
There you can confirm that both 2.4 and 5G networks exist.  If you like you can also give them friendly, meaningful names, set the encryption type and set their passwords to your preference.  Note, the printer requires a 2.4 GHz broadcast that uses WPA2 encryption.  🙂
Stephen
Moderator
Moderator
