05-18-2013 12:20 AM
What size memory card goes into the PowerShot A520 camera?...and where can I get one?
05-18-2013 03:11 AM - edited 05-18-2013 03:15 AM
This camera uses SD card. You can buy it from any online or local electronic store. It should not cost more than $7. But don't mistake it with SDHC card. Your camera is not compatible with SDHC card. SD card is limited at 2Gb; so the largest one you can get is 2Gb. Anything larger will be SDHC.
One from amazon: http://www.amazon.com/SanDisk-Flash-Memory-Card-SDSDB-002G-AFFP/dp/B007JRB0QA/ref=sr_1_4?s=pc&ie=UTF...
