01-11-2014 02:25 PM
Hello All,
I am a new member on the message boards. Owner of a Canon Power Shot SX50 HS.
I enjoy nature and take lots of bird, butterfly, deer, etc. shots. Also scenery shots.
I do not understand the setting on this camera and I only use the auto mode.
Question: What are the best settings (Apature and ISO) for the type of pictures I take. Some come out sharp but lots have a blur. Suggestions wlecome.......Thanks!
01-18-2014 08:38 PM
Very nice tutorial and you do indeed have some excellent photos from your SX50. WELL DONE.
01-18-2014 09:01 PM
Hi cicopo,
Thank you very much! I'll continue to edit / update my SX50 post as I discover more about the SX50 and look forward to sharing this information with you and fellow forum members.
Best regards,
Tony
01-18-2014 09:53 PM
Tony, thank you for your reply on the Canon PowerShot SX50. I do not have a manual, so, I can not refer to page 57. Where would I find the "Framing Assist - Lock"? What shutter speed should I be using on the SX50 for birds and wildlife? Also settings for scenery shots? In Manual mode I have ISO set at 160, 1/800 and F5.6. My screen goes black in Manual Mode and I have -2 showing in red.
I am going to look at your gallery as soon as I post this. Thanks for any expaining and help you can offer. I do appreciate it.
01-18-2014 09:54 PM
I think it might be a good idea to copy & paste your 2 lengthy messages here too.
That will double the availability of finding the info using the search function.
01-18-2014 10:14 PM
Hello, Tony.......I have look at both your galleries. Your photos are just beautiful and SO DETAILED. Love the way you capture the eyes and feathers of the birds. Love your work! Thanks for sharing!
01-19-2014 11:43 AM - edited 01-19-2014 11:49 AM
Hi GloriaS,
First, I’m the quintessential button pusher and experimenter when it comes to camera settings. I’ve never taken a photography class so my level of “technical” knowledge will be rather limited. The following information is as deep as I can go with regard to offering advice and is based upon what I’ve experienced through observation, practice and experimentation. Therefore, perhaps some of the more technically savvy forum members should always feel free to spackle over some glaring holes I may have missed! I’m as eager to learn as much as you are about the art and science of photography and shared information is certainly the currency of any thriving forum!
The “manual” is on the CD that came with the camera. For convenience, here’s a link to Canon’s online version of the manual:Canon SX50 HS Manual
To see the location of the Framing Assist-Lock scroll down to page 4 and look for the circled number 11. As you press and hold down this button while composing the shot the icon for the Framing Assist-Lock you see pictured on page 4 appears in the viewfinder / LCD to confirm it’s been activated. Be sure to keep the button pressed until you’ve finished taking the shot!
There isn’t a definitive or default shutter speed or aperture setting I use for birds & wildlife or any subject, for that matter. It depends more on things like the available amount of sunlight and if the subject is moving or not and how much depth of field I’m interested in capturing in the image. I think in these simple terms; shutter speed settings determine how long the shutter remains open and aperture settings determine how wide the lens opens when taking the photo and also affects depth of field. Both affect the amount of light entering the camera and these two factors ultimately influence exposure. When I’m shooting in Shutter Priority or Aperture Priority Modes, I also adjust Exposure Compensation levels to further affect exposure. For example, if I’m composing the shot and the image on my LCD looks too dark, I’ll try decreasing the shutter speed or adjusting the aperture value. I might also need to increase the Exposure Compensation levels until I achieve the overall level of brightness or darkness I want for that particular photo. Then I’ll take the shot. I’ll try this before I increase the ISO in order to keep overall visible “noise” to a minimum. The higher the ISO, the brighter the image, but the potential for "noisy" or grainy images escalates. I haven’t shot any images above ISO 400 so I’ve no idea how well this camera would do noise wise in this case. One benefit though for increasing the ISO in situations of low-light is that it allows you to increase the shutter speed! This fact alone can help minimize hand-held camera shake! Although I’ve never used it, apparently Sports Mode is popular for capturing moving subjects.
Even for photographing birds not in flight I always use the fastest (highest) shutter speed possible given the amount of sunlight I have to work with primarily to reduce hand-held camera shake. Also, when the angle of lighting is favorable and a bird is in a position where there’s plenty of direct sunlight on it yet the background is fairly dim, then one of my favorite techniques appears in any of my images where the background is black although the bird, for example, remains well lighted. Please see my Canon SOOC Gallery to see how close I get to blackening the background without losing much brightness on the bird, before I do any post-processing to further darken the background. This is a result of controlling the amount of light I want to enter the camera by manipulating shutter speed, aperture, and exposure compensation settings. I intentionally steer the settings toward the direction I want in order to create the mood I want. I love visual contrast in my bird photos. By using this method I can “vanish” unsightly and distracting objects such as branches, signs, and even a section of a bridge in a couple of my pigeon photos! All by simply manipulating the settings. It’s more important to me to have fun and create the image I desire rather than settle for what the original scene presents.
I believe it’s extremely important to develop a certain style and approach to photography. Ask three people to photograph the same rose and more than likely each will approach the rose from a completely different angle and with a completely different artistic vision. I value more drama and visual impact in my bird & wildlife photos than I do accuracy. I’m not interested in creating a bird guide or accurate visual “document” of the encounter.
If I were to photograph scenery I’d most likely try using Aperture Priority Mode or Manual Modes since I’d have greater control over the depth of field in the shot. Depending on whether (or weather!) or not I wanted objects in the distance to be in better focus I’d adjust the aperture values accordingly. The closer to f/8, the more in focus the background is, the further away from f/8, the less in focus the background would be. The actual distance between the foreground subject and the background also factors in, as well.
If I were in a situation where in Manual Mode the ISO was set at 160, shutter speed at 1/800 and aperture at 5.6 as you described and my screen went black, first I’d try decreasing the shutter speed or adjusting the aperture setting to see if this solved the problem and or then I’d try to further increase the ISO or Exposure Compensation levels. Unless I'm mistaken, in Manual mode you don’t have access to change exposure compensation settings, so one or a combination of these other strategies should brighten the image on the screen. To be sure, indoors and even outdoors the camera’s flash or an external flash can really help, as well.
Best regards,
Tony
01-19-2014 02:49 PM
Way to go! You have successfully hijacked Gloria's thread.
01-19-2014 02:54 PM - edited 01-19-2014 03:50 PM
Hi Gary,
I'm doing my best to directly help Gloria (and others reading this post) with her SX50 and that was the reason for my post here.
Gloria requested suggestions from forum members regarding camera settings that might prove helpful to her. She did so here in this section of the Forums. She responded and had further questions from me. I'm new here so where am I supposed to offer and post direct advice to someone with a specific question or request other than the section of the Forums where the original thread started?
Tony
01-21-2014 04:20 AM
Tony! Your input on this thread should be made essential reading for all on this Forum wanting to understand this great Camera and wish to share their "tips" and "tricks".
I come from a video, Film & Edit background, and your "Hands-On" style/experience and the way you've expressed it here, is great to read and easy to understand.
I'd underline 2 of your great points:
A] Light is everything.
B] Giving examples of what and where you use settings is essential in understanding.
I can't wait for your next posting - CLICK!
Grazie
