02-13-2016 07:04 PM
While I am trying to focus on a subject why does my Canon ELPH 160 show the message: "Display will turn off. Any operation reactivates"? I cannot focus with a black display, and tapping a button disturbs the focus. I could understand this if the battery were low, but this happens even with a fresh charge. Is there a setting that I can change to disable this message?
02-13-2016 07:12 PM
Yes in your settings menu there is a Power saving setting where you can ajust the time before the display goes blank
Here is the link to your user guide that information is on page 74
http://gdlp01.c-wss.com/gds/1/0300017431/01/elph170is-160-cu-en.pdf
02-13-2016 07:12 PM
02-14-2016 01:56 PM - edited 02-14-2016 02:02 PM
Thank you! I figured it out - was the ECO setting that had to be changed first in order for me to access Power Settings. ![]()
02-14-2016 02:04 PM
Ok great!
06-25-2024 05:35 PM
Can u please tell me step-by-step for the canon power shot sx740hs please?
06-27-2024 07:11 PM
Hello Jasleen70,
The PowerShot SX740 HS also has the Power-Saving feature as well as a feature called ECO Mode. You would want to check each of these settings. They can be found on page 101 in the user's guide. I have included a link to the manual HERE for your reference.
