powershot elph 360 hs photos blurry
almxas
Hi I just got the powershot elph 360 hs new from canon. All I did was turn the flash on and all the images are blurry and not focusing. I’ve messed around with the different setting but I’m truly lost. Sometimes there’s a yellow square in the middle of the screen with a small explanation point probably something wrong with the focus?
2 REPLIES 2
f8_Rebel
Almxas:
If you turned the flash on because there is low light, then maybe there's not quite enough light for the camera to focus properly. I think there is a focus assist beam on that camera. Read the manual to find out how to turn it on. The focus assist is just a small beam of light that the camera casts on the image during focusing in low light, allowing the camera to attain focus. See if that helps.
Natfaw
Hello were you able to fix this issue? I’m having the same thing
Holiday
