10-21-2023 11:21 AM
after a small drop (no damage to exterior) the power button doesn't seem to operate correctly. If I hold it down, and keep it pressed, I can use the camera as usual with no apparent issues (focus, settings, zoom, flash, all work) but the second I release the button, the camera shuts off and the lens never retracts.
I would like to know if this is an easy fix or something more serious, and how much will it approximately cost
10-23-2023 06:26 PM
Greetings Sulvin,
Per your description, we would recommend on sending the unit to our facility for service. You may begin the repair process online through our online repair portal where the website will provide an estimate for service, along with instructions on how to send the camera to our facility.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
05-19-2024
12:27 PM
12:34 PM
Stephen
Hi Sulvin,
did you send in the Camera and did Canon manage to solve the issue (and how)?
several people on the internet (including me) seem to have the same problem.
[Removed links per Community Guidelines]
10-02-2025 05:50 AM
Any updates? Were you able to get the repair done? What did it turn out to be, and how much did it cost?
12-10-2025 08:26 PM
i have same problem. any luck with yours? Thank you!
