10-10-2022 08:02 PM
in auto mode, when i tap the screen to focus where i want the camera gives me a different and very tiny focus box with an exclamation point. its not focused and wont allow me to choose what i want.
10-11-2022 07:07 PM
Greetings pineapple_2910,
One thing to check is to see if the rear LCD display is clean from debris since this may prevent the camera from registering where on the screen you may be touching. You may use a dry microfiber cloth to wipe the screen. I would also suggest checking the front lens element when the camera is powered on to ensure it's free from debris.
Sometimes the camera may have trouble focusing if there isn't enough light in your environment of if there isn't sufficient contrast on the subject.
You may also reset the camera to factory defaults to see if it helps resolve the auto focusing issue. Page 288 of the user guide will provide steps on how to reset the camera.
https://gdlp01.c-wss.com/gds/8/0300035728/04/psg7x-mk3-ug4-en.pdf
In case the issue persists then you may send the PowerShot G7 X Mark III to our facility for service.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
