charging a powershot battery in greece
kholl1957
is there anything special to know about charging a battery for the SX260 in Greece? I have an adaptor/converter with different plugs.  Do I need anything else?
1 REPLY 1
Skirball
You should be fine, but double check the back of the charger just to be sure.  It should say something along the lines of “Voltage 100 – 240V, 50 – 60 Hz”.   Most of Europe uses a 220V @ 50 Hz, compared to the US at 110 @ 60 Hz.  The charger can accommodate any of these inputs so long as you have the converter to plug it into the wall.
