SX740HS lens cover getting stuck
CyberKnight
I've had a problem for the last few years that the lens cover does not fully open or fully close most of the time when the camera is turned on or off. It will go part way but it seems like the spring that would normally finish opening or closing it is no longer strong enough to fully push it all the way out or in like it should. Has anyone found a fix for this issue? If not, could you direct me towards a good tutorial or video for disassembling the camera in order to fix the mechanism?
0 REPLIES 0
Canon LIVE! Canon LIVE!
