SX50HS LED screen won;t come on.
Heynav06
My SX50HS LED screen won;t come on.  I've tried resetting using the display button but it still doesn't come on. The shutter appears to be working as a I can take pictures using the view finder.  The LED does come on to review the photos at which time I can visually access all basic settings.  However, the LED will not come on using the power, display or menu buttons, Any thoughts?  Thank you
1 REPLY 1
John_
That is odd
I would try pressing the Display button till the viewfinder turns off then at that point hold the Display button down for at least 1 second
Also would try resetting to defaults thru the settings menu
And 1 last thing Id take out the battery and hold the power On switch in the On position for at least 30 seconds then replace the battery and try it again
I own 2 SX50HS's
Friends and Family
