05-01-2013 07:10 PM - edited 05-05-2013 10:54 AM
UPDATED May 5:
I apologize to the forum for mixing two different problems. They are unrelated.
Problem #1: User error. I thought I was using a class 6 SD card but I was wrong. The yellow "!" indicates a pathologically slow card. Upgrading to a class 10 resolved this problem.
Problem #2: UNRESOLVED. Red battery indicator comes on prematurely. On a fresh charge, it'll turn red after recording for a couple of minutes. On a partially drained battery, it turns red immediately upon entering movie mode or pressing the record button. Turn the camera off and then right back on in "still" mode and it shows full charge and works fine ... until trying to shoot video. I have not precisely measured recording times but it'll record for at least 20 (maybe 30?) minutes while flashing red.
06-04-2013 06:45 PM
06-04-2013 08:37 PM
Union: Not rhetorical at all. Everybody needs a hobby, and clearly your "heat" is bringing Canon swiftly to its knees. Knock yourself out, and let us know when someone cries uncle.
BTW, read my post. I wasn't "questioning your right to comment, and in fact said so. I just honestly wondered why anyone who had already returned their camera would bother to do so. Logical question.
06-04-2013 10:15 PM
I just returned my SX280 as well. Disappointing! I really don't want to hit the market again. I made an assumption based on the Canon name and on the positive reviews of the earlier SX260.
06-04-2013 10:47 PM
06-05-2013 04:48 AM
06-05-2013 05:52 AM
reply to an email, I received the folowing this morning. This is from canon uk.....
Dear Mr. White,
Thank you for your reply.
We would like to inform you that there are no known issues regarding PowerShot SX280 HS. If there were any known issues, they would be announced in the important information under PowerShot SX280 HS on our Canon website.
06-05-2013 06:55 AM
If you use Camera Window (Canon software) to download images, the opening window gives battery capacity. I had the camera in M mode when I connected the camera via USB, I turned it on and opened Camera Window. This was the display:
I then turned the camera off, changed to movie mode, and turned the camera on with USB still connected. I opened Camera Window and this was displayed:
I guess all this indicates is that Camera Window displays battery capacity as reported by the battery level indicator but clearly the battery cannot have two widely disparate levels at the same time. Incidentally, I turned the camera off a third time, changed mode to auto and turned it back on. This time Camera Window again reported the battery capacity as full.
06-05-2013 08:21 AM
Videophan is the Camera Utilities accurate when it comes to firmware? The firmware on mine (sent back to Canon for a fix and in transit being returned to me as I type) is Firmware: 1-14.0.1.0. I plan on checking the new firmware data when I receive the camera back.
06-05-2013 08:39 AM
Here is the SX 280 firmware update USA-
https://www.usa.canon.com/cusa/support/consumer?pageKeyCode=prdAdvDetail&docId=0901e024808f7d56
06-05-2013 08:40 AM - edited 06-05-2013 08:56 AM
Yeeha! Even before Jessica told us here!
Canon USA, UK and Europe has it, but not yet Belgium - will come through later I guess (translation needed?).
More info on the fix in the support page:
1. Increases the duration of movie shooting by 20% in cases where the optical zoom is used compared to cameras running Firmware Version 1.0.0.0 or Firmware Version 1.0.1.0 ...
2. Fixes a phenomenon with cameras running firmware version 1.0.0.0, in which the low battery level warning is prematurely displayed while shooting in movie mode.
I will try this tonight and report back!
Regards,
Filip.
