11-27-2016 10:13 AM
Yesterday was the big test for my new PowerShot SX60 HS. Yes, I know it's apparently a 2014 model.
The results at a music festival two weekends ago were good. Beautiful sunny days.
The same at the arboretum on Thanksgiving day.
But, yesterday for the event I wait for each year, the Junior Rodeo, it was overcast.
The parade shots at 10:00 AM were better than the rodeo shots as the clouds were somewhat darker after noontime at the arena.
No matter what I tried, the photos were grainy.
For comparison, I used AUTO. Then tried different settings as practice since I knew I could go again today.
Tried the cloudy day setting.
Tried different ISO settings, Tv, Av, M with various combinations to no avail.
When I pressed the shutter half way, by 4:30 PM I had to keep fiddling with different settings until it looked bright enough. I had to have a high ISO to see anything. Then, I used the flash not expecting much because I am so far away being outside of the fence. Miserable results.
I knew I'd need a fast shutter speed and planned on at least 1/500.
Read so many articles online and paid attention to the advice from
11-27-2016 10:58 AM
This is hard to diagnose without a photo example to look at.
Graininess, and also poor detail when zoomed in are symptoms of shots taken at ISO levels beyond the camera's particular ability to handle high ISO. The higher the ISO the more grain and noise, and the less resolution detail in the image. The fact that it is worse in less light tends to support this guess. The small sensor of a powershot will not do as well at higher ISO as a camera with a larger sensor.
Suggestions.
Avoid cropping. Blowing up the picture makes any deficits in resolution more glaring. Try to get as close as you can and then try to frame tightly in camera so you don't have to crop/blow up your image.
On less than sunny days, use as slow a shutter as possible without getting motion blur. If you can get a blur free shot at one four hundredth of a second, don't shoot at one thousandth of a second. It robs you of light and that makes the camera raise the ISO even more.
Get as as close as possible instead of relying on the superzoom to bring the action to you. The lens has a variable aperture. The lens stops down more and more as you zoom in. Stoping down is pinching the lens opening smaller, letting in less light, which makes the camera raise ISO. It may also make the camera speed up the shutter to combat blur, but the faster shutter also diminishes the light getting into the camera, and forces it to raise ISO.
11-27-2016 11:45 AM
Thanks for you response.
I did try among numerous settings, ISO 100, which is just where I wanted it. Lousy results.
AUTO did some with ISO 100.
Yes, I surely noticed the cropping effect, but have had better luck in previous years with a couple of Olympus and a couple of Kodak camers. I have never until now tried anything except AUTO. I got some beauties other years, but did notice cloudy days weren't so special.
Looking at the EXIF I see one series of five shots from yesterday which had to be on AUTO or I was using Av f/5.6
ISO 200 1/400
ISO 160 1/320
ISO 100 1/160
ISO 200 1/320
ISO 160 1/400
All at 95.33mm I certainly zoomed in to get him coming out of the chute across the arena. Total of 8 seconds. I like that part.
Each of these were grainy - not super grainy. Funny, most of the animals don't look so grainy, but people faces sure do.
[Get as as close as possible instead of relying on the superzoom to bring the action to you. The lens has a variable aperture. The lens stops down more and more as you zoom in. Stoping down is pinching the lens opening smaller, letting in less light, which makes the camera raise ISO. It may also make the camera speed up the shutter to combat blur, but the faster shutter also diminishes the light getting into the camera, and forces it to raise ISO. ]
Very interesting.
Being at the rodeo means the closest I can get is at the fence, but I am not tall enough to see over the fencing/railing and have actually shot between the rails. To get height, I get to the top of the stands and stand on the top row. Now I'm about 20 feet further away. That's why I love the great zoom capability of cameras.
I zoom in as close as I can, but those horses are flying by coming at different angles. You never know which way the calves will turn with the team ropers chasing after them. Exciting.
The sun is coming through now with high thin clouds, so I will be heading over in an hour or so. It's just about five minutes away. I bring my iPad and can download to it when there is a break in the action.
My first shots will be on AUTO to see what it will do for me. Not expecting a lot now that you mentioned the zoom effect.
Then, I will try 1/400 at ISO 100. Maybe I should use Tv to force that speed.....I did that several times yesterday.
I might try some without any zoom at all and see what I can see after downloading. Maybe cropping then wouldn't be so bad.
Thanks so much for you input....especial about the pinching. Rats!!! I really like to zoom in.
I will post samples later, but I will have to make them smaller to post here.
11-28-2016 02:28 PM - edited 11-28-2016 02:33 PM
I went back Sunday when it was less cloudy. ...mostly in and out.
By the time they got to the steer and bull riding which I really wanted to get some pictures of, it was getting windier and cloudier with the exception of the chutes across from where I could get a view of those two events
Throughout that time the sun was shining from behind me onto the chutes across the arena.
Yes, sunlight is the key.
Here are four examples of what I was able to get:
ISO 100 f/5.6 1/400
ISO 200 f/5.6 1/1,000
ISO 100 f/5.6 1/400
08-20-2024 05:22 AM - edited 08-20-2024 05:41 AM
I had several versions of the SX##HS cameras from the SX40IS to the SX60HS. The challenge with these cameras is their tiny sensor size - about the same as that for a cell phone. The big draw of them is their compact size and the massive zoom range.
As you have experienced, they work well enough in good light, but those tiny photosites (the light wells that capture pixels of light), are much less efficient that those of large sensors, and are thus prone to noise in anything less than bright conditions. That said, you want to keep your ISO as low as possible - I tended to shoot on auto ISO limited to 400 FWIW.
Also, convention suggests you want to keep your shutter speed up to something approaching the inverse of your equivalent focal range, which for the SX60HS is 24-1365mm. So even though the camera does have image stabilization, for fairly fast moving subjects you need a fast shutter speed. You might want to look at some of the videos on You Tube relevant to Rodeo photography: photographing rodeos - YouTube to get an idea of their settings.
Cameras, like so many things, are compromises between price, size, weight, and performance. I finally moved away from the SX series and purchased a completely different brand of bridge camera, the amazing Sony RX-10MkIV which, even after almost 7 years, is still considered best in class. The images are worlds away in terms of quality.
