05-08-2021 06:48 PM
I am getting a continual problem on my videos. Too much noise.
This can be seen here:
https://www.youtube.com/watch?v=xODkPppDbcU
'Noise" might not be the most accurate word - but what I mean
is the "activity" that is ever-present. I see this even when I use
spotlight on other vids. I am mostly concerned with indoor videos
with moderate lighting. Any ideas on aperture, ISO settings, HD, etc?
Thanks.
05-08-2021 09:15 PM
You need to add additional lighting.
05-08-2021 10:40 PM
There are three main things resulting in the poorer video quality:
The equipment itself; your camera has a small sensor. As such, unless you have lots of good lighting, it won't lead to higher quality. Though there will be a limit to what this camera can do.
The codec used to record the video. Consumer cameras actually toss out lots of information and then tend to use very heavy compression.
The compression applied by YouTube.
Unfortunately, you're stuck with the codec (consumer equipment typically just has one type). But, you can, as mentioned earlier, try to add more lighting. I would also use a shutter as low as possible. Typically you want the 180-degree rule. And if your camera allows for it, I would recommend shooting at 24 fps (actually this will be 23.976, but that's a whole other discussion). For the sake of this post, I'll write 24. So shutter can be 1/48 second. This will give you for light-gathering performance over using 30 fps with a shutter of 1/60. Small, but still worthwhile.
For aperture, you'll want the widest possible and that typically means widest angle of the lens (least zoomed in).
Last restort is ISO; set that as low as possible. Typically professional video equipment have native ISOs (e.g. 800), but I think for typical photo cameras that also capture video, lower ISO is better.
05-09-2021 01:10 AM
Hi musicus,
Thanks for checking in!
The suggestions on here from others have been valid points, in particular keeping the ISO as low as possible while still getting a proper exposure is one of the best things you can do on the camera side to reduce noise.
I will add that if you find yourself shooting more videos, you might think about upgrading to a camera with a larger image sensor like the PowerShot G1X Mark III, which has an APS-C CMOS sensor, like many of our DSLRs. Generally speaking, the larger the image sensor, the better the camera will be at capturing detail with less noise, especially in low-light conditions.
A newer processor can also help. The PowerShot SX170 IS uses our DIGIC 4 processor, while the G1X Mark III has our DIGIC 7 processor. To learn more about our G-series PowerShots, check out the link below:
https://www.usa.canon.com/internet/portal/us/home/explore/powershot-g-series/powershot-g1-x-mark-iii
05-09-2021 08:00 AM
Got sidetracked a bit during my earlier reply... Regarding shutter, while 180-degree rule is very common, you could also slow the shutter further in order to reduce ISO. Note though that motion will appear different. Anyhow, use 1/24 (1/25) shutter for 24 fps movies. And 1/30 shutter for 30 fps movies.
05-09-2021 02:20 PM - edited 05-09-2021 02:31 PM
Thank you, I appreciate your taking the time to respond. I think I need to be
sure that my using the word "noise" is correct. So I'm linking or attaching a
few examples of videos I took with my Powershot. I would like to know
whether any of these could be considered visually unacceptable ("noise?") by most
viewers, in your opinion. I know they could all be sharper, of course. (Note: I only used
one camera so I don't know whether the 180 degree rule applies.)
https://www.youtube.com/watch?v=wVvLQvW_YWw
This is zoomed not from Powershot but from iMovie.
https://www.youtube.com/watch?v=tcZGBY45m9o
Notice the "activity" on the right side of the piano (lower
R corner of the frame)
Within the first few seconds notice the "activity" during the
zoom. Zoom was done with iMovie.
I will try to check out your three main suggestions regarding
frames per second, aperture and zooming, to see how to
access this on the camera. Looking forward to your reply.
Thanks.
05-09-2021 02:25 PM
Thanks. I am trying to make sure that my use of the word "noise" is correct so I have posted three examples:
I want to make sure that I have done everything possible on my Powershot
before I go out and spend big bucks on another camera. Do any of the above
videos appear to be visually unacceptable to you? Of course I know they could all be
sharper. Thanks.
05-09-2021 02:30 PM
05-09-2021 02:56 PM - edited 05-09-2021 02:56 PM
It sounds like your issue only appears when you zoom into the frame using iMovie. Sounds like an editing software issue.
05-09-2021 02:57 PM - edited 05-09-2021 03:08 PM
My fault for mentioning it as the "180 degree rule". Yea, that involves filming a typical scene of a conversation between two people.
Anyhow, I should have used "180 degree shutter angle". That means to use a shutter that is one over double the frame rate. So for 24 fps movies, you'd use 1/48 s (1/50 s) shutter. And for 30 fps movies, you'd use 1/60 s shutter.
