07-28-2014 03:15 PM
Does the lens completely retract when not in use on the Powershot Elph 150?
07-30-2014 02:02 PM
It should retract as far as the bezel when not powered up. If not, remove the battery and make sure it is fully charged, then insert that battery into the camera and press the power button. If it does not retract, then you may have a stuck lens.
Steve M.
