Powershot ELPH 180 shooting modes
ashleyariii
Hi! I was wondering how I can have access to the shooting modes on the ELPH 180, I’ve looked at the manual and the directions on there has not helped : for instance I pressed the auto button and it switches between AUTO and SUPER VIVID. I have a trip coming up and I desperately need to change the shooting modes and learn how to. Thanks for the help
6 REPLIES 6
rs-eos
I would take another look at page 37 of the User Manual.   Here's a portion of that page which says to press the upwards-pointing triangle button several times.   Page 43 I believe then outlines P (Program) mode.
Ricky
Hi! I really appreciate taking time to reply to my question because I am so stressed on how to work it. My question is what button is that  upwards-pointing triangle button because if it’s the auto button I’ve already pressed it several times and it only switches back from auto and super vivid. I’ve looked at the manual and am confused on what is that upwards triangle button to press, I can’t do anything without knowing what button is that.
It appears it's the auto button:
It may be worthwhile to reset the camera's settings.  Perhaps something got set that is preventing it from switching amongst the various modes.  To reset the settings, see page 74.  But here's an image with most of the instructions:
Ricky
camilarz
Hey! did you ever figure this out? I’m having the exact same issue
Hello ashleyariii,
Try pressing the FUNC./SET button. This should bring up some settings down the left side of the LCD screen. Locate the shooting mode, and then press the right directional arrow to move over to the list of additional shooting modes. Use the up and/or down arrows to scroll to the desired shooting mode and press the SET button to select that mode.
Hello ashleyariii,
Follow the below steps once you have set the camera to the Super Vivid mode.
