04-04-2023 05:54 PM
Hi! I was wondering how I can have access to the shooting modes on the ELPH 180, I’ve looked at the manual and the directions on there has not helped : for instance I pressed the auto button and it switches between AUTO and SUPER VIVID. I have a trip coming up and I desperately need to change the shooting modes and learn how to. Thanks for the help
04-04-2023 08:00 PM
I would take another look at page 37 of the User Manual. Here's a portion of that page which says to press the upwards-pointing triangle button several times. Page 43 I believe then outlines P (Program) mode.
04-04-2023 08:15 PM - edited 04-04-2023 08:15 PM
Hi! I really appreciate taking time to reply to my question because I am so stressed on how to work it. My question is what button is that upwards-pointing triangle button because if it’s the auto button I’ve already pressed it several times and it only switches back from auto and super vivid. I’ve looked at the manual and am confused on what is that upwards triangle button to press, I can’t do anything without knowing what button is that.
04-04-2023 09:53 PM
It appears it's the auto button:
It may be worthwhile to reset the camera's settings. Perhaps something got set that is preventing it from switching amongst the various modes. To reset the settings, see page 74. But here's an image with most of the instructions:
05-22-2023 05:21 PM
Hello ashleyariii,
Try pressing the FUNC./SET button. This should bring up some settings down the left side of the LCD screen. Locate the shooting mode, and then press the right directional arrow to move over to the list of additional shooting modes. Use the up and/or down arrows to scroll to the desired shooting mode and press the SET button to select that mode.
05-22-2023 05:35 PM
Hello ashleyariii,
Follow the below steps once you have set the camera to the Super Vivid mode.
05-21-2023 04:31 AM
Hey! did you ever figure this out? I’m having the exact same issue
