04-04-2026 10:30 AM
I've used this camera for photos and now I have a need to video/audio record a presentation and would like your suggestions on how to based on the following:
Here's what I have:
Questions/Comments:
Thank you in advance for your assistance, support, guidance.
04-15-2026 06:00 PM
” Can I use a USB power supply such as a power bank, plug into a charging block - using appropriate cables? “
I don’t know if Canon ever sold a “battery eliminator” package with an AC adapter for the camera. The Usrr Guide should tell you what Canon accessories are available.
The User Guide should also tell you whether you can power the camera through the USB port.
Exercise caution ⚠️ trying to power the camera using the USB port. Be sure to follow the guidelines on the manual. If it doesn’t specifically say how to do something, then conclude that you cannot and should not try it.
