05-02-2016 02:58 PM
Since some time the TV function of my Canon S100 does not work anymore. I especially bought the camera to control shutterspeeds, but alas, the only thing I see when I turn the lensring is ISO or zoom specs, from 28 mm and so on.
At last I tried to install firmware again, but whatever I tried, in the menu (after pushing Playback) the choiche 'Firmware' did not appear.
What to do now? All suggestions are welconme.
05-02-2016 03:03 PM
Have you tried taking picture in that mode? If you can only see adjustment for aperture, then that sounds like Av mode, not Tv.
Do ALL of the other modes seem to work properly? Tv mode should allow you to set a shutter speed, but not an aperture value.
05-02-2016 03:13 PM
Pehaps you accidentally reassigned the control ring ? You can try resseting to defualts thru the setting menu or try resetting it using this procedure
05-02-2016 03:31 PM
I tried everything according to the manual. Whatever I choose, the result after turning the ring is ISO, Over/Under and so on. But no shutterspeeds...
05-02-2016 03:42 PM
hmmm...not a good sign. As a last ditch, hail mary have you removed the battery, held the power switch to the on position for at least 30 seconds, replaced the battery and tried it again? In rare cases that has worked for various "glitches".
05-02-2016 03:58 PM
Nope.
05-02-2016 04:42 PM - edited 05-02-2016 04:43 PM
Does it work when you don't use the ring to set the shutter speed? You should be able to use the screen.
05-02-2016 04:55 PM
Whatever I try, I never found any shutterspeed.
Tried to reset firmware (who knows it helps), but according to download information there would be the choice 'Firmware' in the menu., adter pushing 'Playback', to set firmware back.
Alas, no 'Firmware' to find in S100 menu.
05-02-2016 05:11 PM
Use the "M" mode and the shutter speed is set by the dial on the back.
05-02-2016 05:18 PM
No sir.
