04-03-2023
11:59 AM
09:34 AM
I have a Canon 5.0 MegaPixels Camera and every time I open the screen, it says 'Memory Card Error' at the top. I've searched for how to fix this but haven't found anything that has worked yet. I've changed the memory card, formatted it and etc. and nothing has worked for me and I was wondering if I could have some help. It doesn't allow me to zoom in or out and doesn't allow me to take any photos, nor does it focus either. Hoping I can get some help -- Thanks!
04-03-2023 06:48 PM
How about saying what camera this is? "5 MegaPixels" is no help.
What type of memory card does it have, CF or SD? If CF, look in bottom of card slot to see if there are any missing or bent pins. If SD, look in to see if there's anything stuck in the card slot.
Are you formatting the cards in the camera or on a computer? It sounds like the latter since the camera says there's a memory card error.
04-03-2023 06:48 PM
04-08-2023 04:33 PM
Thank you! I apologize, I'm not too good with cameras so I apologize but this solved my problem! There were bent pins - I'll try to get that fixed. But again, thank you so much!
04-08-2023 06:51 PM - edited 04-08-2023 06:52 PM
You're welcome, but you don't have to be "good with cameras" to look at it and see what model camera it is!
Unbending CF card pins is chancy. They break very easily. Good luck.
