IXUS 60 Memory Card Error
jtruong
Hi, i’m currently having the same problem. I have the ixus 60 and have tried an old and new SDHC cards. I have also tried them in a different camera and these SDHC cards work fine. Does the ixus 60 not take SDHC or is there something wrong with my camera?
thank you.
6 REPLIES 6
kvbarkley
The manual will be very clear as to which cards to use. Also, make sure to use full size cards and not a micro card with adapter
kvbarkley
Your camera only takes SD cards "tested up to 2 GB"
normadel
SD cards that are larger and faster than what the camera needs should not be a problem, but there may be a limit.. The specs say "tested up to 2 GB" because 18 years ago (when this camera came out), 2 GB was a "large" size. It may well take 4 or 8 GB cards. But that big is overkill, capacity-wise.
You don't say what size your cards are, but if they work fine in another camera, I'd say your camera is the culprit.
But I am pretty sure that SDHC, SDXC and SDUC are right out, they have more differences than just size.
I see! Thank you so much, I have been using micro 32GB SDHC. I will try the SD 2GB.
Make sure to get a full size card. Micro's with adapters don't play well with Canons
