11-24-2018 08:33 PM
11-25-2018 10:38 AM
There is nothing wrong with your camera. It sounds like you are pixel peeping the images.
Video frames do not have the resolution of still photos. Photos of distant objects do not have the resolution, or appear as sharp, and photos of objects that close to the camera. Try taking more still photos. The secret to being good at shooting video is having a good understanding of shooting stills, and what is known as the Exposure Triangle and Depth-of-Field.
01-08-2020 05:59 AM
Did you ever figure out what the problem was? I ask because I also have the G7X Mark II and I'm also a new user and my videos are very grainy. To be honest the quality is almost as bad as videos on my cell phone and I don't exactly have a top of the line cell phone either. It's just a crummy old LG Stylus that came out a good 6 years ago. I'm almost worried that some how I have messed up the lense. I've recorded a half dozen videos all using the "AUTO" settings (or at least I think it's AUTO) since that's the setting I have the dial set to. Every single video is grainy and it doesn't seem to matter of the lighting in the room or outside. I didn't seem to have this issue with the very first few videos I recorded when I first purchased the camera. But I've now had the camera for a year (barely used it during that time) and now I'm actually wanting to finally figure out the camera so I can start using it way more frequently. I'm nervous I some how messed up the lense but I'm hoping it's just some sort of filter or option that I didn't realize was engaged. I'm very new to photography. I'd like to say that I'm great with understanding angles and what angles work best when taking photos, but as far as all the options when it comes to cameras settings that's something I've never understood.
01-09-2020 01:55 AM
Hi Mista808,
Do you have any examples you can show? The lens would not affect graniness but there may be another setting being implemented in the automatic shooting mode that can change the look of the footage. For example, if the camera selects a high ISO (1000, 3200, or higher) you will likely get graininess and if that is the case you can moe the mode dial to "P" and manually adjust the ISO down to a better level.
01-09-2020 02:21 PM
was able to fix the graniness issue but I'm still having issues with a small white dot that is appearing in my videos when I'm recording in low light situations. I found out with more expensive DSLR's there is a fix for this by doing the manual cleaning method but with these GX7 Mark II's apparently we have no way to fix this?
02-25-2020 03:47 AM
how did you fix the grainy videos on your camera? I still have not found the solution
05-10-2021 11:39 AM
05-10-2021 02:59 PM
@Evampire wrote:
Did you find any answer for the bouncing white dot? I’ve got the same thing in low light videos and noticed that YouTube vloggers with same camera also have it
It almost sounds like dirt/dust on the image sensor.
05-11-2021 01:36 AM
05-11-2021 08:10 AM
Hello!
If you have an issue with your camera, and you're concerned that it's malfunctioning, we strongly encourage you to have it evaluated.
To start the process, log into your My Canon Account and set up a repair.
If you're outside of the United States, please reach out to Canon in your country or region for assistance by clicking HERE.
