08-14-2018 05:09 AM
The camera all of a sudden will not connect to my computer wirelessly. I have found the network, put in the password and it just keeps searching and searching. The camera is only a few feet from my router.
08-14-2018 05:01 PM
Hi DLG16,
Thanks for posting.
To allow us to better assist you, please reply with the following information:
08-15-2018 06:30 AM
Win 7 Professional
Yes, it did connect in the past; that is the problem nothing changed
Yes OS is up to date
I have used it several times b/c I do eBay pics and it is so convenient and all of a sudden it won't work.
08-15-2018 10:50 AM
Hi DLG16,
Thanks for your reply.
Since no updates or changes have occurred to your computer, it's possible that something has changed on your camera. To check for this, I recommend erasing your camera's Wi-Fi settings, then reentering them. For information on resetting your camera's Wi-Fi to default settings, please click here.
08-15-2018 07:55 PM
I already did that, I reset all the settings and put them back in and it still does not work.
Any other suggestions?
08-15-2018 07:45 PM
@DLG16 wrote:The camera all of a sudden will not connect to my computer wirelessly. I have found the network, put in the password and it just keeps searching and searching. The camera is only a few feet from my router.
Did your router update? Those symptoms are consistent with a login from an invalid MAC address. Resetting your camera’s Wi-Fi settings, and deleting all of the old Wi-Fi setups is a good idea.
08-15-2018 07:57 PM
I already reset all the wifi settings but it still does not work.
I don't know if the router has been updated or not.
08-15-2018 08:09 PM
@DLG16 wrote:I already reset all the wifi settings but it still does not work.
Check the router’s security settings. Do you filter MAC addresses?
08-16-2018 06:27 AM
Sorry, check "what" router settings? What specifically? I matched the pathway with the camera, i.e. WSK,etc.
I don't know what you mean by "filter MAC addresses" .
08-16-2018 05:14 PM
Hi DLG16,
Thank you for your reply.
MAC Filtering restricts access to your router, using MAC addresses. You'd have to set your router for this to use it.
I recommend checking the "services" on your computer. These services allow your computer to recognize and connect to your camera. For a step-by-step description of this, please click here.
