External power supply
timgor
Hello, I have a question about external power supply for Canon powershot cameras.
Regular battey use about 3.6V to power the cameras.
Some cameras can work with external power supply and they rate as 4.3V
First question: 4.3V value sounds very strange to me. Is it made specifically that users would buy only recommended 4.3V adapter and wouldn't buy any other? I tried to measure real voltage and it varies plus minus 0.1V
Second question: What is the top safe voltage that I can use for my camera? Can I use 5V for exmaple? 5V power supply costs $1.
If somebody don't have an answer I can make a test and "fry" my old camera by increasing the voltage.
I know that lowest voltage is 2.3V (2.2V just shut down the camera).
This is question to experienced users, not to officcial Canon representatives Man Wink
21 REPLIES 21
Waddizzle
Experienced users purchase the AC Adapters from Canon.
John_
lol yeah dont commit PowerShot suicide spring for the Canon power supplies!!
Are you serious? I should not publish that sort of investigation?
Bu
I understand what you mean. How Canon would explain me why it's real power supply voltage is 4.5V while it says 4.3V?
Are you testing it loaded or unloaded?
@timgor wrote:
Bu
Who knows.  It could be differences between your measurement methods and theirs.  I can think of half a dozen reasons, ranging from rectification to root mean square.
What do you mean loaded or unloaded? With zooming and lightning charging?
If you don't know the answer you should not be playing with it.
A typical digital multimeter has an impedance of millions of ohms, and draws very little current when you make a measurement. Due to its internal resistance a power supply will lower its voltage as the current drawn from it increases.
Your multimeter does not look like the same resistance as the camera so the voltage is higher.
If you need to ask, then you really shouldn't be bothering with power supplies.
