11-27-2023 11:19 AM - last edited on 11-27-2023 01:02 PM by Kristoff
Starting about a few months ago using my usual downloading procedure of photos from my SX610 HS Canon camera, I found the steps to accomplish this feat new and confusing. I need some simple instructions on how to do this.
Here were my usual procedure steps that I used to follow:
But now, after step 3 above, I find a new screen titled “Canon PowerShot SX610 HS”:
In the upper left corner of this new screen are the following options:
All photos
Memories
Favorites
Folders
External Devices
In the top line of the screen is an item Import
In the very center of the screen are the pictures in the camera.
I’m lost on how to proceed from here to successfully load pictures from Camera to Laptop.
Can someone tell if there is a short video (or a write up) that explains the utility (how to work) this screen and were to find it?
I do not have a smart phone.
How do I make it work to load pictures from my Canon Camera to my Laptop using the connecting cable?
Help!
Gary [removed personal information]
11-27-2023 06:09 PM
OK .... just treat the Camera as an external data base and grab and drop in Laptop Folder.
This won't mess up the Camera? Will try. Tks GB
11-27-2023 04:35 PM
The simple thing to do is disable the utility that is opening automatically when you connect camera to computer. It is what is confusing you.
You don't need any app/utility to copy/move from camera to computer. Connecting them should mount the camera on computer as a drive in File Explorer. Then you open the drive, open the DCIM folder, and copy/move the photo files to wherever you want them to go.
11-27-2023 06:09 PM
11-28-2023 01:15 PM
No, it will not mess up the camera. It's just moving files.
