01-10-2020 10:38 AM
Canon lists the specs for an SD memory card for the PowerShote S3 IS as:
Image Storage
01-10-2020 11:23 AM
Not sure why you brought up CompactFlash.
Anyway, the maximum it can handle is the maximum of the listed cards, in this case SDHC which goes to 32 GB.
For my T6S, it specifies
So I can also use SDXC which allows for 2 TB(!)
01-10-2020 01:49 PM
So, if the PowerShot S3 IS can take SDHC memory cards up to 32 Gb, are there any restrictions on the class of the card (such as Class 4) and transfer speed (such as 48Mb/s), or will ANY SDHC card up to 32 Gb work on this camera?
Thanks.
@kvbarkley wrote:Not sure why you brought up CompactFlash.
01-10-2020 02:15 PM
Any SDHC should work, but higher speeds may just be wasted. At some point it won't be the card holding things back.
