Canon powershot SX730 HS
raindaisy1318
I just recently bought a canon powershot sx730hs and it's saying there is no memory card in and there is we just bought a brand new one, is there anything we can do to fix this problem?
John_
Is it a full-size SD card or a micro card in an adapter? Those micros in an adapter can cause problems like this and a full-sized card is always a better choice. You could have a bad card or somehow dirt got into the SD card slot or worse a faulty new camera. Look in the SD card slot for signs of dirt or something and try another full-size card with fingers crossed. If not then it is time to give Canon a call for warranty service unless you can bring the camera back to where you bought it for an exchange. If they will only repair it then I would try and deal with Canon direct it will shorten the wait time.
3 REPLIES 3
John_
raindaisy1318
Thank you so much for your help! I had let my husband go get the memory card so he got a micro I normally don't use those so tomorrow we will be getting a full sized SD card I hope that was the problem. Also does it need to be a certian gb? Like 64gb or 32gb?
Your welcome! As far as the capacity of the card that's just your preference and I prefer no larger than 32GB
Friends and Family
