01-07-2015 11:51 PM
How do you override the "Red Eye Correction" when it displays, "cannot be modified"? Is there no "manual" way to correct red eye?
01-08-2015 07:14 PM
Try the software approach. You'll find you can correct red eye, horizons, exposure etc very quickly once you play around with Picasa. I use it for the majority of my editing & I have to edit many 1000's of photos per year.
01-08-2015 05:06 PM
I don't have that camera but I'm not sure I understand your problem. Are you trying to prevent the camera from doing the red eye correction OR are you looking for a way to fix things when the camera doesn't get it right?
01-08-2015 06:46 PM
01-08-2015 06:55 PM
If you use a PC you can download Picasa (a free editing program which I like) & use it. Picasa has a lot of very easy to use functions, plus it's a nice library organizer. The Canon software bundled with the camera may also do it but because I've used Picasa for so long I haven't put any effort in learning the Canon programs other than DPP.
01-08-2015 07:07 PM
01-08-2015 07:14 PM
