Canon NB-10L battery for G-15. I need a replacement. What do the 920mAm etc. mean
tombloom
My G-15 original battery, NB-10L is failing.  When I look for a replacement, the numbers after the 7.4Voltage don't match.  Is this important.  My original says 920mAh 6.8Wh(Li-on).    Replacements I'm looking at on line, while still 7.4 V, say things like 1300mAh 9.6Wh(Li-om).      Is this a critical difference, or will the replacements still work and not hurt the camera?  Tom Bloom
Thank you!!    Set my heart at rest.  A perfect answer, I appreciate it.   Tom
2 REPLIES 2
smack53
Mentor
Tom,
The important numbers are the NB-10L and the 7.4v. The other numbers are for the milliamp hours and Watt-hours. The higher the number, the longer the battery should last. It's an indicator of how much power the battery can store. Many times, the original battery that comes with the camera are not as long lasting as the replacements simply because they are cheaper for the manufacurer to include. It's kind of like the battery for your car. A 72 month battery holds more charge than a 60 month battery, and is more expensive to buy. So in your case, the replacement 1300mAh battery will last longer per charge than the original 920mAh battery.
Steve M.
