ā12-16-2025 10:20 PM
I have been having a situation while having fully charged batteries in the CF-R20EP with cooling fan that the camera shuts down says the batteries need to be charged or replaced. I turn the camera off pull the batteries and reinsert them and the camera then functions. can happen a couple of times in a row. The fan is turned off as the temps have been in the low 30s and 40s,
Is any one else experiencing this issue
TIA
Don
ā12-17-2025 05:36 AM
Suggestions for use. Mount the grip empty. Load Canon LP-E6P batteries after it's installed.
If you continue to have issues please contact Canon support. Start by registering your product in your MyCanon account, then call support.
https://myprofile.americas.canon.com/us/signin
1-800-652-2666
ā12-24-2025 10:43 AM
i have done all of that multiple times ane yes my camera ha been registered since date of purchase.
ā12-24-2025 02:27 PM - edited ā12-24-2025 02:36 PM
ā i have done all of that multiple times ane yes my camera ha been registered since date of purchase. ā
Do you checked the battery charge periodically. I assume that you are using the LP-E6P batteries. Did you buy them from Canon?
Does the issue arise without the grip?
Are you filming video or capturing stills?
What lens(es) are you using? Is the issue lens specific?
