Canon G7X memory card Error
liasigut
Hello all Im having a "memory card error" on my G7X. The memory card im using is the SanDisk 128G Extreme PRO SDXC UHS-I memory card, SD card. Not sure what to do from here. Any help is greatly appreaciated
1 REPLY 1
Waddizzle
I recommend that you try using a much lower capacity card, 32 GB or smaller.  What is the exact error message?
Do not use micro-SD cards that require the use of a plastic adapter.  Those will always fail, usually straight out of the packaging.
Always format your memory cards in the camera prior to first use.  Never swap memory cards between different devices.  Avoid buying camera accessories like memory cards, batteries, lens, etc on Amazon.  Only buy memory cards from a Canon Factory Authorized Dealer.
Friends and Family
