08-22-2015 04:07 PM
I'm having trouble connecting to my computer about a month ago I don't have this trouble now I can't even transfer my pictures to my pc,either or the camera will show not connected, cannot detect, not found ... I have check everything but still the same. did follow on setting up wifi connections did uninstal and reinstall camera software still the same,your help is appreciated.Thank you.
08-23-2015 02:42 AM
Spend $15.00 at WalMart or anywhere and get a card reader. A little plastic thing that plugs into any USB port. You stick your SD (or other) card into it and then it is just like any disk drive on the computer. You dont need to worry about getting the camera and the computer to talk.
For the camera:
Try rebotting the computer WHILE the camera is connected. Turn computer off and on again WHILE the camera is connected.
08-23-2015 08:25 PM
Thank you so much I highly appreciated your answer.
08-23-2015 09:52 PM
Is your computer running Windows 10. There are issues with the Wireless connection to Windows 10. However you should connect with the USB cable.
