Can the G15 Canon housing be fitted for a wide angle lens?
rhscubadiver
I have a G15 and the Canon housing. Would like to be able to attach a wide angle lens to the housing when needed. Any advice or suggestions would be greatly appreciated. Thanks.
2 REPLIES 2
cicopo
I recommend that you ask your question here (you'll need to join)
http://www.scubaboard.com/forums/canon-corner/
or here
http://wetpixel.com/forums/index.php?showforum=1
after searching each to see if the answer & method is already there. I know that with my G9 it requires some mods to allow using add on filters / wide angle conversion lenses.
Thanks a bunch, will also check out the other sites for any possibilities.
