03-17-2024
05:19 PM
02:20 PM
SamanthaW
Hi everyone! I have a SX740 HS that I’m using for shooting video of football games. When I go to record, it sometimes works and sometimes goes “BUSY” and have to take the battery out to reset the camera. Any idea why this would be happening?
I have a picture of the micro SD card I am using and video settings.
03-17-2024 05:51 PM
The first thing you'll hear from many is to NOT use Micro-SD cards in adapters. Numerous cameras don't seem to like them Use full-size SD cards.
Also, very large capacity cards can be problematic for some cameras. Do you have smaller onesto try?
03-17-2024 06:42 PM - edited 03-17-2024 06:43 PM
Start here.
03-17-2024 07:00 PM
The issue is almost certainly your memory card. The User Guide does not list micro-SD cards as a recommend type of memory card. Yes, that’s correct. They are not the same as a full-size SD card.
Buy a new Class, 10, UHS-1 SD memory card from a Canon Factory Authorized Dealer. Buying memory cards, camera batteries, and other camera accessories on web sites like Amazon is highly inadvisable.
I buy memory cards from B&H. I always low-level format them in the camera prior to first use, too. Despite appearances to the contrary, memory cards do not come pre-formatted. They have residue from production testing, which needs to be completely wiped away.
Never swaps memory cards between cameras or devices that use them to store data.
03-17-2024 07:15 PM
I have a 32GB micro that I was using and was doing the same thing.
03-17-2024 07:15 PM
I will try this and see what happens.
03-17-2024 07:17 PM
I did buy this camera from B&H. I will look into full a full SD card.
03-18-2024 12:01 AM
@Acogley81 wrote:I did buy this camera from B&H. I will look into full a full SD card.
Do not buy the largest capacity cards out there, either. Stick to 32GB or 64GB cards.
03-18-2024 06:42 PM
Shoot! I ordered a 128 GB. Should I return it and get a 64 GB?
03-18-2024 07:47 PM
@Acogley81 wrote:Shoot! I ordered a 128 GB. Should I return it and get a 64 GB?
A major brand like SanDisk or Lexar should be find. What did you order?
