12-26-2020 02:31 AM
I was having issues with the print driver not applying the toner density settings via the print driver, even though they were working fine when I set them on the printer itself.
I realized in the print settings, in addition to changing the toner density settings, I also needed to change the "Toner Density Adjustment" setting from "Printer default" to "On".
Sharing here in case it helps someone else.
02-11-2021 10:21 AM
Hi, georgec22!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
