06-26-2020
07:24 AM
09:49 AM
I am a photographer from Montenegro.
I have a printer Canon PRO4000 and I have had a problem with it for the
past couple of months. We are a small country and we do not have any
kind of service support here and because of the global pandemic it is
impossible for a foreign service to come and help me fix it. The
problem with the printer is the ink keeps running out really fast and
the printer is showing that the cartridge is empty. I already replaced
2 that I had I opened the back of the machine and found the ink in a
subtank which is underneath the cartridge. It is an MBK on the left
and a PC on the right side, I cleaned all the parts and replaced the
ink but the same thing happened again. Does anyone know what could be the
problem because all the parts seem to be okay?
If anyone has a similar experience or know anything about this, I would be very
grateful for yours help!
Thank you in advance,
Dejan Kalezić
06-26-2020 04:28 PM
Hi DejanKalezic.
As you have noticed, the PRO-4000 features a reservoir to which the cartridges drain. For this reason, the initial inks may seem to not last as long; the ink is there, merely syphoned to the reservoir to reduce the likelihood of print problems (air in the line, drying ink, etc.).
When the printer is deprived of power (such as when it's unplugged, or powered off by a wall switch or power strip), it will be unable to tell how long it's been powered off, and so it will do a more full cleaning when it next powers on than it would if it remained powered (whether on or off).
Canon has a branch in Montenegro. If you haven't already done so, you may try contacting them through their website: https://www.canon.me/support/
06-26-2020 05:30 PM
Ink is located in ink supply mount unit L (number 5). It leaked in there from sub ink tank unit L. I can see the ink dripping from there. I cleaned everything, and I didn't find anything to be damaged.
The workers from Canon in Montenegro came and we cleaned the printer together, but when I put the new cartriage with ink, after 1 or 2 prints the ink leaked again.
Because of COVID-19 it's impossible for a person from another country to come and help me find a solution.
Could you help me find the cause of the problem?
This printer is the only one in my country (Montenegro- a very small country) and I can't get help except this way.
Dejan
01-23-2021 10:50 AM - edited 01-23-2021 10:54 AM
Hi Dejan,
i'm a french photographer with the same Canon Pro-4000 since three years.
it was always a good product that i'm very happy.
Since last week i had a the same probleme like you. My 700 ml MK cartridge will ended a little bit quickly. I don't think first there was a mistake. Today, four days after i put a new 700ml MK cartridge, i found the cartridge empty.
Waouuhhhh ! there is a big problem : 700ml of ink disapeared and nothing on the ground, nothing in the plastic covers !
So there is a similar problem between us and maybe a conception fail in !!!
ANd do you know today more about this problem ?? can you help me more precisely ? Do you find any solutions ? Where did the ink go ?
I wish you find the way to repair it and now i can repair it too.
THanks.
ERic
10-10-2021 06:13 PM
Dejan did you end up finding out what your issue was? I have the exact same issue and I'm looking down into the Ink supply mount and see all my MBK sitting down there.
10-03-2022 09:45 PM
Hello, My printer has also drained 3 cartridges of ink 300ml each instantly has anyone found out why thus happens?
08-16-2024 09:00 AM
Anyone have a fix?
08-16-2024 09:12 AM
Hi !
Like Dejan i changed all the parts (Number 12) of my two side cardbridge support ! It's easy but you need some professional command that i don't remenber (maybe the unit dealer can told you 😉 I'll fix it doing in the same time the upgrade of the printer that i did never done. I think that today i have to see if there is a new upgrade !! 😉
I found in italy a dealers 2 times less expensive than in France (https://www.digigate.it/)
08-16-2024 09:21 AM
I need too upgrade : Mine is 2.23, the newest from march is
ImagePROGRAF PRO-4000 Firmware Ver.2.25
