01-16-2016 05:51 PM
PIXMA MX922 purchased 2+ years ago, has worked fine but just recently the print quality is down the tubes. It prints orange'ish for straight black. Check pattern looks weird.
I've tried deep cleaning and regular cleaning. I've replaced all ink cartridges. I use ink from PrintPal, which I've used for years, on other printers as well.
01-21-2016 04:18 AM - edited 01-21-2016 04:21 AM
Hi williampeck1958,
If you have already performed at least one cleaning and two deep cleanings on the printer, we recommend replacing the inks in the printer with Canon genuine inks to try and resolve the issue. Unfortunately, we cannot guarantee the quality, reliablity or compatibility of refilled or third-party inks being used in the printer.
Should you still experience difficulty, the printer may require servicing; we ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) for further assistance. There is no charge for this call.
Hi williampeck1958,
01-24-2016 09:49 AM
I did replace the ink, no luck. Will get approved ink now.
05-23-2020 09:00 AM
I do not accept this as the solution because I have used the same ink for years. It seems that something else is going on.
05-23-2020 05:38 PM
