10-01-2023
09:23 PM
10:09 AM
I setup a samba server on linux and want to scan from my MFC8380 to a share on that server. I am getting error #801. I want to confirm the format of how to input the share information on the printers address book. I have the following:
Type : SMB
Hostname 192.168.1.10
folderpath: scan
username: user
set password: password
Does that look okay? If I connect to my samba share I would normally connect to \\192.168.1.10\scan with the user and password. That works fine from windows and linux. However, I am not sure if the printer wants the hostname as "192.168.1.10" or "\\192.168.1.10". And does it want the folder as "scan" or "\scan".
If that's not the issue, anything else I should look into? I also set my samba server to allow samba v1.0 connections and tested it. So that should not be an issue. Both printer and server are in the same network.
10-02-2023 02:13 AM
Maybe this will help.
Configuring SMB - Canon - imageCLASS MF8580Cdw MF8280Cw MF8210Cn - User's Guide (Product Manual)
