12-01-2023
12:40 PM
12:41 PM
Prints perfectly on regular paper, but when i put labels in it jams.
is there a settign to print on label paper?
12-02-2023 05:34 AM - edited 12-02-2023 05:35 AM
I sometimes print labels for the telephones at my church. The supplier of the blank labels provides a backer that is affixed to the bottom of the sheet. Think of the backer as an 8.5"×11" "Post-It Note".
Using the backer prevents the sheet from jamming in the printer.
Under "Paper Settings", there are some options (I have a 743) to select different paper media. I'm not sure if labels is a choice though. 🤔
12-02-2023 04:41 PM
Where is the label sheet jamming? Going in, inside, coming out...? Are labels coming off the sheet inside the printer?
12-02-2023 04:44 PM
It jams halfway through the page. They are UPS labels. The labels are 2 per page, so if I remove the bottom sticker it will print the top label. The labels are not coming off during printing. I think the label page is too thick. i used settings to set it for heavier paper but it made no difference.
12-02-2023 05:01 PM
You've answered your own question. The sheet is most flexible in the middle between the two labels. Bending the sheet around the paper path is causing it to hang-up on something. With the bottom label off, the sheet can roll through the printer more easily. Can you get some label paper that is a solid sheet? You'd have to cut the sheet with a scissor and peel from the edges, but if it works, so what?
01-27-2024 04:49 PM
I'm having this same issue with mine too.
Cutting the label paper in half and then basically cropping my label file and then printing them from my computer one at a time helps but it's a tedious, time consuming PITA - otherwise the attached video happens.
This basically makes my $600 printer a giant paper weight since I use my printer to print shipping labels for my online business.
No matter what paper setting I use, a full sheet will not make it all the through and there's a notable "hot rubber" smell to the machine and label paper after printing.
There is a specific label setting that does NOT work when set both from my computer printer properties as well as my printer's page settings.
I've tried the following settings: Label paper, heavy paper (all weights) and Plain paper (all weights) along with other random settings.
I'm going mad with this!
Attached Video:
01-27-2024 04:59 PM
Cutting the label paper in half and then basically cropping my label file and then printing them from my computer one at a time helps but it's a tedious, time-consuming PITA - otherwise the attached video happens.
Attached Video:
01-27-2024 05:07 PM
When I print DESIs for telephones at home and at my church, the company that manufacturers the labels & software provides backers (essentially an 8.5×11 Post-It Note) for the label sheets.
The label sheets jam without the backer. With the backer...no problems.
This applies to my 743Cdw and my church's 733Cdw. 🙂
01-27-2024 05:12 PM
It does have the option for labels. Please read my entire comment.
01-27-2024 05:18 PM - edited 01-27-2024 05:21 PM
I am aware of the label setting. In my use case, that doesn't come into play as the software takes care of printing in the defined spots on the DESIs.
