imageCLASS MF743Cdw Mac Cannot Find Scanner
SteveEdiger
This is a new installation on a Mac PowerBook Pro with M1 chip.
OS version is Ventura 13.1
Downloaded lastest drivers and utilities from Cannon:
  • mac-scan-v21511-00.dmg
  • mac-UFRII-LIPSLX-v101913-10.dmg
Installed drivers and set up all-in-one to work wirelessly.
Adding a printer/scanner from System Preferences / Printers & Scanners results in
  • Canon MF741C/MF743C printer (works)
  • Canon MF741C/MF743C fax (probably works, I don't  have a phone line
  • nothing for a scanner.
I go to MF Toolbox:
  • No scanner appears
  • Clicking on Network Scanner Settings and Adding a Scanner results in
  • Bonjour shows no scanners
  • Adding scanner in IP address mode results in: The specified scanner is not supported.
Rebooted both laptop and MF743Cdw.  Repeated installation.  Same results
2 REPLIES 2
What driver appears for the Printer in its properties?
If Bonjour or AirPrint, the scanner will not appear.
Jblevins775
I had the very same issue, and it was driving me crazy! I installed, deleted and reinstalled so many times. I finally deleted the printer from the Printers and Scanners page under settings. I then clicked Add Printer. Selected the same printer THEN I check "Share This Printer on the Network" and everything started working again. Hope this helps.
