imageCLASS MF733Cdw - email to Print Issue
Meghan2000
I setup my printer for "email to print" so I can email a PDF or DOC file to the printer and have it printed. I setup the POP and SMTP accounts properly and created a special printer email address on my email server, and verified that I can Scan and send to an external email. However when I send a PDF to the printer via the printer email address, the email and PDF is received - I can see it in the Rx Job Log of the web UI - but it does not print and shows an Error Code #818 which is:  "The received data is not in a printable file format". According to the "remedy" for this I am supposed to "Ask the sender to change the file format and resend the data".  This does not make sense since it is a PDF which is an acceptable format. I verified that the PDF is not corrupted and also sent a PDF as an attachment from several different email accounts, all with the same error.
Help Please!!!  I need this to work and can't find any answers on the web. Has anyone got this to work?
Thanks!
Meghan
13 REPLIES 13
Greetings Mehgan,
What OS (Windows or MAC, version and build) are you using the printer with?
More importantly, what application or program are you using to create .PDF's with?
Hi Rick,
Using Windows 10 to send the email to the printer. The PDF was created using Microsoft Word using Microsoft Print to PDF driver. I think I know what you are getting at - I'll try it with a PDF that was created by something else.
Thanks!
M
Unfortunately.... that did not work. I tried different PDF files from different sources, a DOCX file, a JPG. All of them when received at the printer give me this code #818. Also tried sending the file from two different email clients, but no luck.
Lets try a different way.  Here is a link to the Printer's User Guide.  Please point me to the feature you are trying to use:
Canon - imageCLASS MF735Cdw / MF733Cdw / MF731Cdw / MF634Cdw / MF632Cdw - User's Guide (Product Manu...
Here is a .PDF version of the same guide of that is easier.
imageCLASS MF735Cdw / MF733Cdw / MF731Cdw / MF634Cdw / MF632Cdw User's Guide (c-wss.com)
Hi Rick
The links you sent me don't provide any details of setting up email to print. This one does:
https://oip.manual.canon/USRMA-1738-zz-SS-enUS/contents/SS735_setup_0050.html
As mentioned earlier, the printer is receiving the file fine via email. And I can also scan to email fine. So the POP and SMTP settings are correct. For some reason it just does not seem to recognize the file
btparas
I too have this problem for the iR ADV C5535 and iR ADV 8595 printers. After setting up E-mail and i-Fax on the machines, one out of five emails with single TIFF attachments will fail to print (Job log will show Error #818 or #821).
Background and Details:
We use a fax service (Faxage) that handles our incoming faxes.  This service is configured to email faxed documents after converting them to TIFF attachments.  The emails are then picked up by the canon printers and are printed out (unless the printer says it cannot analyze the attached TIFF file and logs Error# 818 or #821).  If I access those emails with the unprintable attachment on my Windows 10 PC, I can open the attachments without any problems.
Note that all TIFF file attachments are generated by Faxage and all are readable when detached from the emails and opened from a Windows PC.  However, not all of these TIFF attachments can be read (and printed) by the Canon printers.
Tirillo
I have the same issue with my Canon650MF.
Each single files I try to receive through iFax returns the error 821, "The received data has a TIFF analysis error and cannot be processed."
When I test the Pop and SMTP from the interface it works, the printer connects and the emails in the mailbox get unread, but the printer always fails to print with 821.
I can use the scan to mail, it works perfectly 100% of the times.
I'm really desperate. It is a year, since I bought it and I cannot use mail to print.
Can someone share with my a sample .Tiff file that is printable?
This way I can send it to my mailbox and try....
The Canon support is pushing back saying that the tiff files are not well formatted, but I exported them with different applications that convert PDF to Tiff and none has worked.
Any hint is welcome.
Thanks
Following this! I am having the same issue on my MF642C. I see that the emails were definitely successfully received from the RX: Job Log. If you, or anyone else, were able to solve this please inform me!
Thanks in advance.
For in-depth troubleshooting, I recommend contacting phone support at 1-800-OK-CANON (800-652-2666) during normal business hours (weekdays from 9 a.m. to 6 p.m. ET).
