imageCLASS MF663Cdw Printed colors don't match images
dfleisch1
Have a MF663cdw imageclass laser color printer, the printer color will not match color to downloaded images, have tried color calibration according to manual but no sucess, my HP laser matches perfectly but other problems, the reason I got the canon.vPleae help.
1 REPLY 1
Color calibration is not as simple as printing a page from the printer and then putting it on the scanner for calibration.
Your monitors also have to be calibrated in order to accurately represent the colors your printer renders.
Apple devices use overly saturated colors which can affect the printed output.  In Windows, if the selected color profile doesn't match the image, the colors that your printer outputs will also look inaccurate.  Other factors that can affect color accuracy are the media type you choose and the application you're printing from.
So you need to look at the entire workflow starting with monitor calibration, printer, calibration, then the software and media that you're using.
