02-18-2025
09:40 PM
09:47 AM
Hello, we just purchased a MF656Cdw laser printer and it worked well printing from laptop and intermittently from mobile device. It was intermittent i believe due to the printer frequently going into sleep mode. Today, the printer does print from mobile or from laptop so i entered a timeframe to disable the sleep mode. We looked at multiple troubleshooting ideas we found in this forum and the remote UI. We feel like there is something simple we are missing and are almost to the point of starting from scratch with the initial setup. Any help would be appreciated. Today the printer does NOT print from mobile or laptop.
02-18-2025 09:51 PM
Edit: Today, the printer does NOT print from mobile or from laptop, so i entered a timeframe to disable the sleep mode and that did not solve the problem.
02-19-2025 10:03 AM
You do not say what operating system, computer, or type of network you are using, but before disabling sleep mode you may want to try reinstalling the printer, but this time do so using the printer's IP address, and then setting that IP address a static both on the printer and on your router.
06-07-2025 01:24 PM
MREG, this answer saved my printer woes today! My new MF656cdw was taking 12 minutes to print every single page, displaying a "waiting" message during that time. I reinstalled my printer using its IP address, and NOW IT'S WORKING! Thank you so very, very much for this suggestion!
06-08-2025 09:31 AM
Glad to hear it!
02-24-2026 09:54 AM
I have the same printer. Using Windows 10. How to disable suto power off. The printer keeps getting different IP.everytime it powers on. I have no access to the DHCP server. Thanks
02-24-2026 09:57 AM
Please explain installing printer? Do you mean Windows10 print driver or update the printer firmware itself?
03-27-2026 04:34 PM
I have been having the same issue with my new MF665Cdw printer. I mostly print from my iPhone and iPad. Randomly these devices can no longer find/communicate with the printer. When I check the printer, it is in sleep mode. The control panel is unresponsive and will not wake up. I have to reboot the printer for it to function again.
I too have searched for an answer to this issue. I have tried every control panel option suggested as well as the Remove UI console suggestions. The printer will not stop going into this horrible unresponsive sleep state. There is no option/setting to prevent the printer from entering this sleep state. The printer has the latest firmware installed.
If anyone has found an answer to this issue, I would much appreciate it.
03-27-2026 04:36 PM
I too tried setting the "Sleep Mode Exit Time Settings" hoping that this would wake up the printer every morning. Unfortunately, this does NOT prevent the sleep lockup situation.
03-27-2026 04:39 PM
I have set my printer to a static IPV4 address via the printer and in the router. I still have the sleep lockup issue.
