imageCLASS MF652Cw - How to install dual side printing
abmotwt
I just got my ImageClass MF650 and would like to install the automatic dual face printing. Where could I find the process to do it?
Thank you.
Jacques
2 ACCEPTED SOLUTIONS
Correct, the Cdw in the model indicates duplex, so the 652 is simplex.
To print on the other side of the page you have to put the original back into the tray upside down or feed into the multi-purpose feeder upside down.  This way a page can have printing on both sides of a document.  The easiest way to figure this out is to use a pencil and put an "X" on one of the page corners.  Then print.  Now you'll know what the correct orientation is when you re-feed the printed page.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
abmotwt
Yes, thank you that's a good solution. I will use it.
7 REPLIES 7
SamanthaW
Moderator
Moderator
There are a few different models in the imageCLASS series within the 650 line, can you be more specific on the model please?
US Model MF656Cdw - supports duplex
If i-SENSYS, Only the 655 and 657 iSENSYS models support duplex.  The 651 is simplex (one sided).
If supported, this is not something that has to be enabled.  If you are using a supported model with a MAC, you may not have installed the correct driver if the duplex option is not available.
Thank you. My printer's model is imageCLASS MF652Cw
Thank you for your answer. My printer is a 652, so I suppose like the 651 it's simplex. In that case what the easiest way to print "manually" in duplex. Jacques
abmotwt
Hey, Rick!
To be even more precise, "Cdw" = Color duplex wireless, so if a unit is just a "Cw," it's a color wireless model.
Thank you for being such a huge help!
